2013-04-13
07:02 PM
2023-05-23
02:36 PM
Rubia Torres
2013-04-13 11:38 PM
2013-04-14 01:35 AM
"Matthew Lohden" wrote:
That is not a particularly complex roof. It should not be too hard and there's no need for SEOs. Did you use the complex/multi roof tool? I'm not too familiar with that as I learned back when single pitches were the only way.
I assume you mean the you want to get rid of the hips and change them to gables. As separate pitches this is very simple. Just delete the hip part and stretch the peak nodes out to align with the corners of the eaves. If the roof is a single complex assembly I assume you would need to convert it to single pitches first. Perhaps someone with more experience with the "new" ways can explain a bit better.
2013-04-14 02:46 PM
2013-04-14 10:42 PM
2013-04-15 02:11 PM
2013-04-16 08:22 AM
2013-04-16 09:17 PM
"rocorona" wrote:
Yes, I noticed the extra dot and, and the other one that appears later (near the end of video, at 0'46''). They produce more problems, if you try to shift the whole ridge to the side, then try to drag it back. I can't get back a single straight ridge.
Thank for the link, David. So it seems absolutely the same issue... the roof plane that disappears is the one with two more roofs starting from it. But sometime, by chance, the roof works, like at the end of my video, where the result is correct.
2013-04-22 01:42 PM
2013-04-22 02:15 PM
