‎2004-03-12
11:37 PM
‎2023-05-23
03:43 PM
Rubia Torres
‎2004-03-16 11:08 PM
‎2004-03-17 12:56 AM
‎2004-03-17 05:50 AM
Kardelj wrote:The purlin object should have a non-transparent fill in order to cover the object below; check the object settings, there might be one in 2D representation. Make sure that your fills are set to "Use element seetings" in Preferences/Miscellaneous.
I have finished Roof Construction, and I was supprised seeing my purlins are visible on the places they are crossing the rafters. On the section view everything is OK, purlins are under the rafters, but on the plan view there are no any line breakes.
‎2004-03-18 12:37 PM
‎2004-03-18 05:43 PM
Kardelj wrote:
"Cheat" empty fill without frame along by the rafters solved my problem, but it's little bit uncomfortable.
‎2004-03-19 09:43 AM
Kardelj wrote:Have to admit that I have not used the Roof structure - wooden - in the last ... hm ... years. No need here ...
To Djordje:
The main problem is that rafters don't have a non-transparent fill.
There are no any fill settings for purlins and rafters on the Floor Plan Section of the "Object Selection Setting". My fills are set to "Use element settings".
