Rope Moulding creation question
I'm hoping someone might have a good solution for this; I have a client who wants rope moldings accents on a lot of cabinetry, up until now I have been modifying the spiral object in the special conts. folder to create the look but the more I add to this the longer all my processing goes so this is not a good full model solution. I have cadimage’s Profiler tool and we picked up Objective this weekend to maybe model a more efficient way to create this both in my time and in processing time. Thanks
25 REPLIES 25
vistasp
Hi Ralph,
It seems there's nothing that OBJECTiVE can't do. Next thing we'll find out that it also makes coffee! 😉
GS, please make a deal with Ralph for this fantastic object and distribute it like his stunning Modular Joinery Object. You're guaranteed to have more subscriptions coming your way.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Indeed Objective is a very handy tool for that tuff jobs... No doubt...
But in this situation... a "simple" complex profile ( ) and a SEO´ed "Spiral 12" object could easily do the job too...
Again... Prepare for a nightmare polygon...
Ralph Wessel
Mentor
woodz31 wrote:
That looks great, I would be greatly interested in learning the steps to do that, any help or instruction I would appreciate. Thanks in advance.
Refer to the attached image:
  • 1) Select the Regular Profile object bundled with OBJECTiVE, and apply the settings as shown to make it a vertical spiral with a round profile. Note that you can control the smoothness (and number of faces in 3D) using these settings.
    2) Use multiply to repeat this single instance over the required length
    3) You should have something like this
    4) If you want to trim off the top/base of the 'rope', place an elevation alongside it and use OBJECTiVE's Split tool to cut them off
    5) You should finish up with something like this.
You can change the smoothness at any time to control the complexity of the 3D model. The model should be quite practical if the smoothness is set appropriately.
Ralph Wessel BArch
Software Engineer Speckle Systems
Woodz31,
How's that miter work'n for ya? This is made with ArchiCAD only.
Shot at 2009-08-25
Haven't worked the objective moulding into the crown yet but this where I'm at with just useing the ac 11 sprial object set to simple, not bad so far.
looks great!
Well done Woods!
Just to check... How is your machine handling this?
Hi vistasp
Was wondering what you meant by:
"and distribute it like his stunning Modular Joinery Object"
Has the MJO been distributed?
And if yes, location?
Thanks
lec
Absolutely "steller" Ralph, woodz31 ,Steve and Braza.
No wonder I gave up on Autocad dos 9 in 1989, trying
to make my own simple "isometric" 3d modular cabinet set
because I could not afford Cabinetware!
My, what 20yrs of innovation has brought us all.
Wow, now I just need to learn it all, someday.
Thanks everyone, this thread has inspired me to try even harder!
lec
vistasp
Thanks
lec
Hi Lec,
See this thread on the MJO and its distribution here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=141436
In a nutshell, GS-UK commissioned Ralph Wessel to create this object and then decided to distribute it to their subscribers. Subsequently, it was given to other distributors worldwide to do the same. Many are/were unaware about its very existence and had to be pushed to contact GS-UK. Mine sent me a CD in the mail within a few days. Your mileage may vary - apparently others have not been as lucky.
= v i s t a s p =
bT Square Peg
