‎2004-11-25
09:00 PM
‎2023-05-23
03:39 PM
Rubia Torres
‎2004-11-26 07:41 PM
mallehk wrote:Unless the lamp has a rotation parameter in its script, you can't. You have to edit the script and add the rotation parameter.
Hi, this is a very easy question.!
How do you rotate your objects in the "Z" Projection?. I want to rotate a
lamp so it has the same inclination which is 25 degrees as the roof.
‎2004-11-27 12:51 AM
‎2004-11-28 07:18 PM
‎2004-11-29 02:16 PM
‎2004-11-29 06:30 PM
mallehk wrote:Welcome!
Thanks for the replies.! And thanks for the lamps Djordje.
‎2004-11-29 06:59 PM
mallehk wrote:Indeed: here it is:
Isn't it a subject for the wish list.??
