Rotate in 3d
Hi, this is a very easy question.!
How do you rotate your objects in the "Z" Projection?. I want to rotate a
lamp so it has the same inclination which is 25 degrees as the roof.
6 REPLIES 6
Djordje
Unless the lamp has a rotation parameter in its script, you can't. You have to edit the script and add the rotation parameter.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
AC does not allow free rotation of elements in 3-space. Some library parts have rotation parameter(s).
If the lamp doesn't, you'll have to add:
ROTX ang
or
ROTY ang
at the top of the 3D script after adding an angular parameter 'ang'.
http://download.graphisoft.com/ftp/publishing/ac9_help/wwhelp/wwhimpl/common/html/wwhelp.htm?context...
http://download.graphisoft.com/ftp/publishing/ac9_help/09-080.htm
If you want the 2D symbol to reflect the rotation, you need to comment out most of the existing 2D script and replace it with
PROJECT2 3, 270, 2
which says to have the 2D symbol be a hidden line projection of the object from a top view.
If this doesn't make sense, mention which lamp it is, or post it, and one of us will modify it and post the revision back.
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
Just as a probable help ...
The ZIP contains a bunch of lamps I scripted half a decade ago in 6.5 for an interior job; used the Projector quite often after that.
Some of them can rotate!
Did not update it for 9, sorry ...
HTH,
Djordje
HP Omen
Thanks for the replies.! And thanks for the lamps Djordje.
Karl: I will try to rotate the objects my self, but if I am not able to do it, I will send you the lamps for rotation.
I really think it is a big problem, that it is so difficult to rotate things in the "Z" projection in 3d or 2d.
Isn't it a subject for the wish list.??
Djordje
Welcome!
In their script you can see how to put the rotation in.
They don't work so well with 9 ... will have to update them.
Djordje
HP Omen
Indeed: here it is:
http://archicad-talk.graphisoft.com/viewtopic.php?p=25221#25221
The Search function for the forum is very powerful. Do find this, I searched just "Wishes" for "topics" that had the word "rotate". 😉
Good luck with your project!
