Learn more
Rotating objects in the vertical plane
I've downloaded a few GDL objects and I can't figure out how to rotate the objects on the vertical plan. I can easily rotate on the horizontal plane, as with all objects. I tried changing the plane to vertical, but that did not help. Any suggestions would be beneficial. Thanks!
2 Replies 2
I'm not sure if this is the right way but try morphing the object. Worked for me.
Correct me if there's a better way forum members.
Try this free Object (Rotator.gsm) for rotating other objects:
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
