SEO doesnt adjust in plan view (shows in 3d)
I've trimmed few objects using SEO, and as seen in the image few of them got trimmed (white ones), but the hatched (terrain) object is shown completely.
- I did not convert the objects to morph since changes are still pending.
if I switch to 3d view,all SEOs are adequately shown (SEO trimmed as should).
could someone explain why certain objects are shown as should in top view, and some are not.
only difference from objects that are displayed properly, and the ones that are not is that the "proper" ones are "roof" objects, and the "wrong" ones are "slabs"
10 Replies 10
Erwin Edel
James wrote:
Erwin wrote:
Roofs do not participate in priority based connections (with building materials), though, where slabs do.
Roofs do participate in priority based connections, just not automatically like Slabs do.
If you use Connect from the context menu between a Roof and other elements, then PBC will be used.
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/elements-of-the-vir...
Indeed, I meant automatically
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
