‎2006-02-17
08:36 PM
‎2023-05-23
03:31 PM
Rubia Torres
‎2006-02-17 08:44 PM
‎2006-02-17 08:58 PM
‎2006-02-17 10:26 PM
‎2006-02-17 10:58 PM
Scott wrote:This (Same Story) requirement has not been my experience with ANY SEO that I perform.
Zobi,
Have you checked to make sure that the mis-performing roof is on the same story as the wall it's trying to trim?
Scott
‎2006-02-17 11:01 PM
Stephen wrote:Maybe that is a fluke too, because most of my operator Roofs have Perpendicular edges.
Zobi,
Check the edges of your roof. When that has happened to me, it is usually because of one of the gable end edges not being vertical.
Steve
‎2006-02-18 04:18 AM
Zobi wrote:Did you try Trim to roof in 3D? Don't see a reason to use SEO on this one, except if you want to keep the trim live.
as you can see from the attached jpeg, one half of the roof works fine, but the other half just doesn't do anything...
‎2006-02-18 05:14 PM
This (Same Story) requirement has not been my experience with ANY SEO that I perform.Yes that is true. I misread Zobi's post and assumed the walls were being 'trimmed to roof'; not sure why one would use SEQ in that example/situation.
‎2006-02-18 06:05 PM
Scott wrote:Nope.
If using trim to roof then either the roof would have to be on the same story, or roof should have 'show on whatever story' parameter checked prior to executing the 'trim to roof' command.
I think....
‎2006-02-18 06:16 PM
The wall has to go through the roof. And you should do it in 3D.I totally agree, but that's the condition Zobi showed in the initial attachment (wall going through roof). I was more interested in why SEO was chosen instead of Trim to Roof to perform the operation. That's all.
