SEO's not showing up on hotlinked modules
Hello all!
I'm having an issue with my SEO's not showing up correctly on my hotlinked modules. In this instance I have a wall that I have subtracted from the stair above it with upward extrusion. It looks good in its original 3d view.
Has anyone figured this out?
2 Replies 2
SEOs with elements within the module will remain. SEOs with elements outside the module will not, and will need to be recreated on the host file once the module is placed (and, I think, redone with every hotlink update; it is probably best to avoid that road).
If you are trimming a wall to a stair, and there is no way you can make that stair part of the same story and module, you could use for SEOing a dummy copy of that stair placed on a normally invisible SEO layer. The dummy stair could be 'on the floor above' in terms of elevation but belong to the same Archicad story and get published with your module.
TsquareCat wrote:
Hello all!
What is the exact setup?
Where is the SEO Target element? In the Host file or in the Module?
And where is the SEO Operator element? In the Host file or in the Module?
