graan
SEO with slanted walls
when executing a SEO with slanted walls as the operator the new surface of the target always will be inherit to the surface of the operator, am I doing something wrong????
AC11-always the latest update available
3 Replies 3
In the SEO toolbox check that you have "Use their own attributes" rather than "Inherit attributes of Operator" selected. (or is the problem that you can't make this selection? or it's not listening)
AFAIK there's no other way of achieving this then using the SEO tool.
I can't manage as well... I presume this can easily be fixed in the next AC hotfix
__archiben
i actually think you are on to a bug. i have noticed similar behaviour but have been too busy to investigate thoroughly. i just thought i must have had the toggle stuart was talking about the wrong way about. but since i rarely have the target inherit the operator's attributes i'm beginning to think it is a bug.
i'll take a closer look . . .
~/archiben
b e n _ f r o s t
