SLAB EDGE NOT SHOWING ASSIGNED MATERIALS
When generating a slab, the materials show up on the floor, but the side (edge) material just shows a greyed out material color, not the actual material shown. I need to show the material for the slab edge.
How do I fix this?
Thanks.
2 REPLIES 2
David Maudlin
dharch:
Which view (section/elevation, 3D Window) is used to view the slab? If 3D Window, then what viewing mode? All these will be part of determining the answer. Posting a screen shot could also help.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I figured it out. I was placing a slab with an original depth of 0", then going back and changing the depth and adding materials. For some reason it would not display the side materials this way.
I re created the slab with the correct parameters FIRST, and it placed fine.
Its just a quirk, but it was driving me crazy.
