2023-09-15 12:34 PM
Hi all, I'm trying to create a custom railing post but can't see the options to save a custom Railing Post? The tutorials suggest File > Libraries and Objects > Save Selection as > Railing Post but I don't have this option. I'm on Archicad 24. Any ideas? Thanks.
Solved! Go to Solution.
2023-09-15 02:12 PM - edited 2023-09-15 02:12 PM
Those custom objects in the lower half in your image are all created by objects in the library.
I removed all of my loaded libraries and they have gone but the stair and railings have remained.
So they must be part of the default program.
All I can think of is that you have a custom Work Environment (or one carried over from an older version) that does not have these commands in it.
You can manually add them.
2023-09-15 01:47 PM
The custom object types are actually created by objects in the library.
Do you have the default Archicad 24 library loaded?
2023-09-15 01:49 PM
Hi Barry, thanks for the reply. Yes I do have the Archicad Library 24 loaded
2023-09-15 11:41 PM
Thanks so much Barry, this did the trick!
