Jordan2
Save Selection As > Railing Post
Hi all, I'm trying to create a custom railing post but can't see the options to save a custom Railing Post?  The tutorials suggest File > Libraries and Objects > Save Selection as > Railing Post but I don't have this option.  I'm on Archicad 24.  Any ideas?  Thanks.
1 Solution
Those custom objects in the lower half in your image are all created by objects in the library.
I removed all of my loaded libraries and they have gone but the stair and railings have remained.
So they must be part of the default program.
All I can think of is that you have a custom Work Environment (or one carried over from an older version) that does not have these commands in it.
You can manually add them.
Go to post
4 Replies 4
The custom object types are actually created by objects in the library.
Do you have the default Archicad 24 library loaded?
Jordan2
Hi Barry, thanks for the reply.  Yes I do have the Archicad Library 24 loaded
Jordan2
Thanks so much Barry, this did the trick!
