Saving in .pdf
This is the case (another one yes).
When i paste on the master layout and edit everything, looks like on the 1st picture.
When i save the layout as .pdf, it looks like on the 2nd picture...
The problem?
not the lines, i know how to edit that, but the insulation... there is none on the .pdf file...
can someone tell me why?
5 Replies 5
Just a guess:
Could it have anything to do with the scale of the Fill Type used for the insulation. Maybe it is too large. I can see some lines in the insulation in the PDF. Maybe the pattern is so large that you can see only this much.
Steve Jepson
Try changing pdf settings.
The problem?
I suspect that you have 'Vectorial Hatching' turned off in the On Screen View Options toolbar in ArchiCAD. This toggles between a faster generating preview of all the fills, and the slower 'true' representation. Your top image looks like the preview, while the PDF looks like the actual fills.
I would recommend turning on Vectorial Hatching on at all times - todays computers are more than fast enough to cope!
Hope that helps.
@steve... its not that...
@peter: where can i change this?
Hi Krasek,
Turn the toolbar on by going to 'Window'>'Toolbars'>'On Screen View Options'
Or go direct to 'View'>'On Screen View Options'>'Vectorial Hatching'.
