ā2014-05-01
09:09 PM
ā2023-05-23
04:26 PM
Rubia Torres
ā2014-05-01 10:35 PM
another Moderator
ā2014-05-02 01:55 AM
ā2014-05-02 03:17 AM
another Moderator
ā2014-05-02 03:20 AM
ā2014-05-04 03:36 PM
Mike wrote:Mike, what happens if you select all these copied elements in Section and then go to the 3D Window. Do they show up there? Can you then check their Floor Plan Display settings to see if they are correctly set?
Anybody else noticing that ArchiCAD lets you copy 3D objects (beams, library parts, etc) in a Section or Elevation window, but when you go back to the Plan window the object/element does not show up? I just spent 15 min copying a beam part 20+ times in a section only to find when I returned to the
Plan window they are nowhere. Not on a different story, not a different renovation status, not on a hidden layer, just NOWHERE. I go back to the Section & there they are, just as they should be, even after a rebuild. Am I missing something?
ā2014-05-04 10:34 PM
ā2014-05-05 04:53 PM
