See-through Fills ?
Is it possible to have a fill with transparent background?
For ex. a fill with a square pattern where one sees just the lines, so it can be placed on top of a drawing and see what's behind. Seeing 'through the fill' so to speak.
Aparently this is very easy in AutoCad.
We have a new person in the office making the 'leap' to AC-9, and trying to get some effects on an elevation.
will appreciate any ideas.
Thanks,
Cedric
1 REPLY 1
Link
Sure you can - use the 0 background fill pen for transparency.
You can also use the -1 pen that will match your background color and also translate to an AutoCAD wipeout if you are exporting out to DWG.
Link.
