Selected items in 3D don't stay selected after editing
Does anyone know why anything i select in 3D will not stay selected after I make a change? I have to reselect in order to make more changes on the info box. This did not happen in AC11 so maybe it is a preference that I am missing?
11 Replies 11
Djordje
Matthew wrote:
Just trying to be more like Revit 😉
Yeah, being yourself is a bad thing ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
jbArch
FWIW, this problem persists after the 2325 hotfix.
Played around some more and noticed that if you select an item (e.g. a wall) in 3D and then edit it, it will appear deselected in the info box. But you can still bring up the wall selection settings with a keystroke, and then edit it from there.
But there's a caveat: when you bring up the wall selection settings, they will be set to the "Default" wall settings.... instead it should give you the actual info for that particular wall.
It's a real mess, and in my opinion this should be a big priority for the next hotfix.
edit: this problem only happens for me in the 3D window, not in the 2D plan.
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
