Selecting an entire layer.
Any way you can select an entire layer?
For example, instead of selecting (lets say the walls tab) and using a simple 'control A' to select all the walls.. is there any way you can select your layer that may consist of multiple different objects such as a layer consisting of both lines and fills or walls and roofs and so on.
I ask this because more often than not I usually end up using a lot of lines and fills to edit my elevations. Doing this, I will put all my lines that I use to touch up my roof, for example, on one layer. And when I go into test printing to check line weights it'd be nice if there was an easier way to select all my roof lines to change the line weight instead of reselecting each line 1 by 1.
Thank you in advance!!
13 Replies 13
goto edit>find and select>all types>more choices>select the arrow in the pen colour box and select layers, you can then choose the layer you want.
Beautiful.. thanks a ton
Laura Yanoviak
You can also use the Quick Layers Palette to isolate one or more Layers. Window > Palettes > Quick Layers OR select an element on the desired Layer(s) and go to Document > Layers > Layer Extras > Hide Others.
daviiiiidave
Hey i got a question for this topic.
Is there a possbility to bind some shortcut for "Select Objects on Layer" ?
I cant find anything in shortcut menu
F&S is a good way but its slow in workflow. I wanna select an Object in 3D hit a combo and it should select all objects in the layer.
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
Find & Select is the only way.
Remember you can store the criteria for later use and you can export/import stored criteria to other files as well.
Other than the Quick options method of hiding all other layers and then select all (CTRL+A)
Steve Jepson
daviiiiidave wrote:
... I wanna select an Object in 3D hit a combo and it should select all objects in the layer.
You can - if - you have made a Layer Combination with the Layers the Objects are on. Otherwise, you can select the Object icon in the Toolbar and use Ctrl-A, to select All Objects. Ctrl-A works like this for selecting all of anything you select in the Toolbar. If you don't want to use the Ctrl-A shortcut, you can Select the Objects icon (for example) in the Toolbar then Edit, and Select All Objects from the pop-up Edit menu.
I am trying to select an entire layer in the newest AC 23 and I am not able to do it....It's a .dwg Autocad file that I am working on it in AC23.
Did you place the DWG file as a Drawing? Or did you use the XREF functionality?
If you placed it as a Drawing then you will not be able to select individual elements within the Drawing, only the Drawing as a whole. You would have to explode the Drawing to then be able to select individual elements from the DWG file.
It's not a drawing.
