2010-03-23
02:33 PM
- last edited on
2023-05-23
02:57 PM
by
Rubia Torres
2010-03-23 02:41 PM
2010-03-23 02:49 PM
splitlid wrote:
goto edit>find and select>all types>more choices>select the arrow in the pen colour box and select layers, you can then choose the layer you want.
2010-03-23 04:45 PM
2017-11-13 09:48 AM
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
2017-11-13 10:29 AM
2017-11-20 10:10 AM
daviiiiidave wrote:You can - if - you have made a Layer Combination with the Layers the Objects are on. Otherwise, you can select the Object icon in the Toolbar and use Ctrl-A, to select All Objects. Ctrl-A works like this for selecting all of anything you select in the Toolbar. If you don't want to use the Ctrl-A shortcut, you can Select the Objects icon (for example) in the Toolbar then Edit, and Select All Objects from the pop-up Edit menu.
... I wanna select an Object in 3D hit a combo and it should select all objects in the layer.
2020-03-13 03:06 PM
2020-03-14 01:03 AM
anto_bg wrote:Did you place the DWG file as a Drawing? Or did you use the XREF functionality?
I am trying to select an entire layer in the newest AC 23 and I am not able to do it....It's a .dwg Autocad file that I am working on it in AC23.
2020-03-16 10:06 AM
