Selecting multiple stories in plan view
Can anyone tell me if it is possible to select multiple stories in 2d window plan view, so that I may copy it?
Thank you.
Edit>Move>'Edit Elements by Stories', or right-click on any of the stories in the Navigator and choose 'Edit Elements by Stories'.
This allows you to copy/cut & paste specific types of elements between different stories. Although I don't think you can copy multiple stories at once, you can do it in several steps.
(This is in AC15 - I presume it is the same in newer versions.)
Hope that helps!
You can use the all storey (thick) marquee to copy and paste but this will be ALL storeys that are copied.
