2004-10-27 09:41 PM
2004-10-28 06:17 AM
2004-10-28 06:44 AM
the single-key shortcuts 'C' and 'G' toggle between the 'construction' and 'geometry' methods for most of the tools, but i can't recall if they work for the selection arrow as well - i know that it doesn't work as it should for the marquee tool . . .Gidday mate - I don't think Arrow or Marquee tools have Construction methods, strictly speaking. Hovering your mouse over the buttons and reading the help tag (rather abruptly) verifies this. What they do have are 'Selection' methods'!
2004-10-28 08:34 AM
jdrulon wrote:You can assign a shortcut. Got to WORK ENVIRONMENT/SHORTCUT SCHEMES/KEYBOARD SHORTCUTS. Choose ARROW TOOL/LAST TOOL TOGGLE in the command list. I've assigned the key to the left of the 1 key--the backwards apostrophe, whatever it's called. I've also assigned it to a button on my trackball and use it constantly.
...Also is there a way to toggle between the arrow tool or marquis tool and other tools?
2004-10-28 06:32 PM
Also is there a way to toggle between the arrow tool or marquis tool and other toolsI use the quick keys to get to the tools: 1 - arrow tool, 2 - marquis. You can of course assign whatever you like. I sure enjoy single key quick keys
2004-10-28 10:34 PM
2005-02-15 07:33 PM
Arrow or Marquee tools have Construction methods, strictly speaking. Hovering your mouse over the buttons and reading the help tag (rather abruptly) verifies this. What they do have are 'Selection' methods'! There is no 'Switch Selection Method' command available in the keyboard shortcut list. They do have Geometry methods though and G does cycle through 'em.
2005-02-15 07:59 PM
