‎2007-08-08
08:52 PM
‎2023-05-26
02:55 PM
Rubia Torres
‎2007-08-08 10:34 PM
‎2007-08-08 10:49 PM
‎2007-08-08 10:54 PM
‎2007-08-09 12:34 AM
‎2007-08-09 01:43 AM
‎2007-08-09 04:19 AM
seattleguy wrote:You don't absolutely need to have the window tool selected - you can just double click the window tool after
Perfect! Thanks
I didn't have the window tool selected when I was using ctrl-A previously... Nice!
‎2007-08-09 03:42 PM
Link wrote:On a related side note, you can also do something like that with dimensions. IF you select a whole bunch of dimensions the double-click the Text tool, it will open the menu for Dimension Text.seattleguy wrote:You don't absolutely need to have the window tool selected - you can just double click the window tool after
Perfect! Thanks
I didn't have the window tool selected when I was using ctrl-A previously... Nice!everythinghas been selected. This is a really fast method if you need to edit many different types of elements one after each other.
Link.
‎2007-08-09 04:49 PM
TomWaltz wrote:Yes, it also applies to fill text, in a similar way.
