Ted Taylor
Setting User Name In Header/Footer
I would like to change the "User Name" in the Header/Footer when printing a quick and dirty, but I can not figure out where it is hidden. Even tried RTFM with no joy. Anybody know the secret?
Thanks
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
3 Replies 3
Jacek
Thanks
Try >Apple P<
or Print and scroll down to <ArchiCAD> -Third bar
Click on the <Header Footer>
Select <Options>
and fill in the blanks as you wish.
Viola or a small cello
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Ted Taylor
Thanks Jacek, I found what I was looking for after turning on Help Tags. The tag for User Name states that the name comes from the operating system. Solution is to go to System Preferences, select Accounts in the System bar and change the name there.
I am not sure this is the most appropriate place for Archicad to be obtaining this info and I would like to see more flexibility in the Header/Footer. If this has not been posted as a wish list item, I will try to do so shortly.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
Djordje
You can always use the Custom field. IMHO it is good to provide the login user name as defined in the system, especially in big networked offices, as then you can keep track who printed what when.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
