Shell tool and Textures
I am unable to Align 3D Textures on a shell. Has anyone else tried this and been able too?
DGSketcher
Legend
I've got the same problem with a simple roof containing a curve.
At the bottom of the roof where the slope is almost vertical and up to about 45 degrees on the curved section the textures and hatch are consistent and correct. After this point the texture and hatch turns 90 degrees!
Am I doing something wrong or is this a known problem with textures on shells?
Is there a fix or work around?
undefined
Has anyone found a work around to this?
Need to create a fluid rainscreen over a main wall which the curtain wall does brilliantly but the hatcing makes it almost non viable.
undefined
