2015-03-04
08:38 AM
2023-05-25
04:59 PM
Rubia Torres
2015-03-04 01:16 PM
another Moderator
2015-03-04 01:44 PM
ejrolon wrote:Thanks. Actually, the first one doesn't work for me. If I click existing polygons with subtract tool, I have to re-active it after each click.
•If you draw the holes first using lines then you can Magic Wand inside them without having to restart
• Also when you select the Slab you can start drawing holes on it without first having to click an edge. For this the procedure is:
•• 1. Select Slab
•• 2. Right Click and Select -Select and Activate Tool or click on the Slab Icon
•• 3. Start Drawing the Holes
2015-03-04 01:57 PM
another Moderator
2015-03-04 03:35 PM
2015-03-04 08:22 PM
Aki wrote:You don't use the pet palette subtraction for this method. Just select the slab, and with the slab tool active, magic wand inside or on the edge of each polygon.ejrolon wrote:Thanks. Actually, the first one doesn't work for me. If I click existing polygons with subtract tool, I have to re-active it after each click.
