LeeJaeYoung
Should I just skip it because I am normal in the entire model?
This is core only.
I want to solve this, but how should I approach it?
In the entire model
Below it appears normal.
(The normal upper part shows the phenomenon described previously.
But this is something I don't see...)
AC27 on window 11
1 Reply 1
Do you need to show a core only view in 3D?
I wouldn't worry about it if it is not important.
So long as the plans are correct if you need a plan with core only.
