Site Plan
Hi, I am using the Australian template and would like to know the best way to go about setting up a view for a site plan. For example, so that the view is showing the roof plan plus the site and planting. Any advise appreciated.
12 Replies 12
David Maudlin
Scotty wrote:
Another question relative to this is, can I just have a cut plane that starts at the highest point of the site down to the lowest, showing everything?
One option is to create a 3D Document. Go to Parallel Projection Settings, set to Top View, set the Camera Azimuth to 270˚, and open the 3D Window, you should have a top down view of the model. Now right-click and select New 3D Document from 3D... and create a 3D Document from the 3D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
dcerezo
Just found this online, I like this method.
https://asiabim.wordpress.com/2018/08/21/site-plan-in-archicad/
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
Tim Ball
I create a 3D view looking down onto the site. Use the plan icon in the 3D menu.
Then create a 3D document and adjust the settings for colours, vector fills and shadows to give you the style you want. Maybe use a graphic override to change the presentation further if you want. You can then use text, labels, dimensions and levels and everything is live linked to the model
Tim Ball
AC26, iMac
User since V5
