archislave
Site display in Section / Elevations
I modeled the site using the mesh tool, although it is not 100% accurate. When I cut the section the cut line of the mesh runs through the foundation wall. What is the best way to deal with this?
Maybe turn off the mesh and draw a cover fill? ... Defeats BIM.
Archislave
archicad 26.0 US, M2 Macbook Air
14 Replies 14
Chadwick
I would do a solid element operation and subtract the footing / foundation from the site mesh.
And if you need a basement cut out, I would do a solid element operation and do subtraction with upwards extrusion. Someone correct me if I am wrong on this.
RA 2012 x64, Piranesi 6 Pro, Sketchup 8, Windows 7 Pro x64, Intel Core i7, 10GB RAM, ATI Radeon Mobile 5870
Do you have the fill background pen set to zero in the wall settings ?
If you change this to pen 91 and send the mesh display order to the back
this should fix the problem.
Peter Devlin
archislave
It strange, but canging the background pen to 91 and bringing to front have no effect. I guess a solid element operation is necessary.
Archislave
That is strange.
I just tested this in AC 10 and it worked.
My mesh has the fill background pen set to 91 as well.
This problem does not occur in AC 9 or AC 8.1.
I just tested it in AC 9 and AC 8.1.
Graphisoft must have changed the section/elevation
default display order for meshes.
I notice that your footing has a similar problem.
Is it's fill background pen set to zero ?
Peter Devlin
archislave
I am also unable to get a floor truss to show when I move it within the floor slab plane. The floor slab background is transparent and the truss is move to the front.
Archislave
I believe what you are describing is normal behavior for AC
and always has been. The way to see the truss when it is
buried inside something else in section/elevation
is to move the section marker so that it cuts through the truss.
Peter Devlin
TomWaltz
The background FILL is transparent, but the slab is still a solid object. It's like trying to see the rebar inside concrete after it's poured... It's part of why I stopped modeling floors as true solids and tend towards sheathing only.
Tom Waltz
archislave
Keep discussing your techniques. I am learning a lot.
Archislave
I have changed over to representing the roof as a Sheathing/Roofing combination and Modeling a Fascia, but I have not "moved" to only representing the floor as sheathing. I have desired to.
Tom, are your walls represented as from floor-to-floor, if so, how are you representing the floor rim in 3D?
For now I am using composites as my floor slabs. Most of the composites represent the sheathing, joist depth and insulation. For representing TJI joist I add a few extra lines in the composite to depict the flanges.
I even have a composite that also represents a 1/2" Gyp-board (Sheetrock) layer below joist. This is nice to represent the sheetrock layer, but the true bottom of the floor slab with reference to the wall is actually at the bottom of the joist not the bottom of sheetrock.
