I had not been aware of this EXTRA tool to do footings. I have been drawing my footings using the wall tool as the wall tool under AC 9 can create a solid line on one side and dashed lines on the other.
This does what you want. As you state, the footing tool does other things that you find more useful.
You may have the only process until GS modifies the tool to get your desired results.
Perhaps you should put a request on the wishlist for future releases of AC 9.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
