2005-08-23
09:07 PM
2023-05-23
05:19 PM
Rubia Torres
Rick, wrote:First ... since this is my second PM in two days from new forum users with theretofore zero posts: I don't get paid to do this. So, please post your question on a forum addressed to the world at large. If you post directly as a PM to me, I'll assume you want to hire me as a consultant (I am a hired gun - I do not work for Graphisoft) and will need to bill you up front.
I'm an archicad software user, i have a question for you regarding the Slab Accessory - Under Footing Settings..
I want to find the way to stretch the footing size, i did explode it, but it didn't work please tell me if there is another way to resize the footing...i was ungrouping the Object to stretch out the Object, but i couldnt do it...Please let me know how to re-adjust it.
2005-08-26 08:33 PM
2005-08-26 08:50 PM
Jay wrote:
That is only the nobodies that were not "special" enough to be selected to the PM group.
James wrote:He just didn't realize that you are two of the smartest guys here!
Apparently just below some specialness threshold,
2005-08-26 09:08 PM
Apparently just below some specialness threshold,I feel your pain brother, but quality is better than quantity right?
2005-08-26 11:28 PM
2005-08-26 11:32 PM
Rick wrote:I have to agree with Rick. Using composite walls is a much easier way than fighting with the accessory a lot of the time.
I use a simple one piece composite, actually several of them... 18", 24" 30" 36" whatever. You then can attach a property object to those collecting the yards of concrete and the amount of rebar. You can pre-set the actual footing depth at 10", 12" etc with your template and/or favorite pallet. Drawing is simple, it's a wall.. so it will stretch if needed along with the wall(s) above.
2005-08-28 12:01 AM
2005-08-28 02:13 PM
2005-08-29 12:51 AM
2005-08-29 12:58 PM
KeesW wrote:I've found the roof tool to be amazing for thickened slabs and haunches on foundations. I especially like it since it does not require SEO to work, so it takes less steps to perform.
I think that the more tricky footing is the one with sloping sides. Until solid modeling came along, was this was best done with the roof tool? I've used the solid modeller and it is a bit tedious, but OK. Are there easier methods?
