Slab Tool
Naahman
Is there any way to make a sloped slab with the slab tool?
Any other suggestions on how to make a sloped slab?
Operating system used: Windows 25
Patricia Angelim
Hi @Naahman
You can use the slab + roof tool to do what you want
the slab tool is only horizontal so if you need like ramps and angles you can do it with other tools such as roof, mesh or even shell.
you can read more discussion here: https://community.graphisoft.com/t5/Modeling/sloping-slab/td-p/288949
or here:
https://community.graphisoft.com/t5/Modeling/Sloping-slabs-etc/td-p/59382/page/2
mthd
Ace
Have you tried using a morph for this operation ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
You might be interested in this article:
https://community.graphisoft.com/t5/Modeling/How-to-Create-a-Flat-Top-Roof/ta-p/303418
Setup info provided by author
