2013-04-02
05:40 AM
2023-05-24
12:48 PM
Rubia Torres
2013-04-02 01:54 PM
2013-04-03 02:23 AM
2013-04-03 02:44 PM
Deviz wrote:Under Renovation Filter Options > Renovation Override Styles > New Elements > Fill Background Color change the pen from 0 (Transparent) to -1 (Window Background) or a white pen.
However, that removes visually the fill (which is a good option to have) but consequentially it shows the lines of slabs below intruding in the slab above. I'd be happy not to show the slab below in that particular drawing, but I'd need to have it shown on the planned status.
2013-04-04 06:33 AM
2013-04-04 02:13 PM
2013-04-04 09:41 PM
Deviz wrote:The background fill colour will only make a difference if you can see the background, so you need to use an empty fill rather than 100% solid.
Thanks David.
...the cover fill currently applied to the slab is a 100% solid with 91 pen on background and foreground. However I tried to change the background to 0 or to -1 as well as changing type of fill, but it made no difference.
2013-04-08 12:43 AM
2013-04-08 01:43 AM
