Slab edge insulation
wendy_neverland
Hello everyone and happy Spring!!
I was wondering if there is a way to have insulation at a slab's edge. Meaning the perimeter part - excuse my English I am not very good in technical terms.
I make the plans of a 3 storied building and I have insulation outside the walls in reality, the insulation is also at the slab edge
Operating system used: Windows 10
CosminF
Hi!
To answer your question: no. Slab composite stack layers vertically not horizontally.
In your case, your wall would continue so that it meets the one above (and thus the thermal layer would be continuous).
And if you want the slab or contour beam there to show up over the masonry, you can do that via the material priority settings.
More on that here: https://help.graphisoft.com/AC/26/INT/_AC26_Help/025_Attributes/025_Attributes-18.htm
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
CosminF
Hi!
Thank you so much for your prompt answer! Yes with the walls works fine, slabs are structural concrete so stronger for walls bricks, so I put the bottom of the wall to the lower side of the slab and it worked like a charm!
Have a nice evening!
Setup info provided by author
