Bill,
Yes my slab does extend to the outer face of the exterior wall. and yes the edge of the slab material is siding. Isn't this the way to do it...Chapter 4:Element Creation, page 90, ArchiCAD 8 user guide. How many other people on the list are doing it this way?
I was wondering about the SEO and how that would work...but it seems much easier to use the -,+ on the pet pallette to cut a hole in the slab.
So you draw your slab within your exterior wall? How do you do that? Do you have an exterior wall which is very thin that extends the entire hgt. of the wall? Or do you have a short thin wall just at the floor, which aligns with the wall below/above?
I know there are many ways to model in ArchiCAD and I am always willing to entertain a new way of doing something. Can you elaborate on how you would construct a simple first floor wall with a second floor slab and a second floor wall?
I am using composites for both the walls and the floor...is there a more efficient way of doing this?
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
