Slab lines thickness...
Llian
Not sure why some of the slab cut lines are thicker when all settings are the same.
Any thoughts?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Guru
Looks a lot like when you have Profiles turned on in Sketchup. Do that stay like that if you pan around so that these edges project towards you? I have never noticed AC doing this...
Ling.
Edit: Are you using the Vectorial Engine? If so, it appears to be defined by the Silhouette Contour 3D Style setting.
Yes, it is the 3D style settings.
