Jae Arif
Slanted Wall Intersection Problem
I have problem for slanted wall intersection,
the view in floor plan. What I expected is not appear correctly.
How I can fix this?
(Please check the attachment).
Thank you.
1 Reply 1
Erwin Edel
As a work around, slabs can have slanted edges and should clean up with walls in terms of building material priority based connections. It would give the floor plan display you are looking for.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
