We value your input!
Snap problem with Arch26 and Mac Sonoma
ssmatsumoto
Recently I had to update to Sonoma. Typically, updating the os would occur well after the bugs have been solved with Archicad. Unfortunately, this time around it is not the case.
Also unfortunately, since the update (to Sonoma), the snap function does not work correctly with most of the tools. This occurs after engaging the a tool.
Is this a known issue? If so, is Graphisoft addressing it and when can an update be expected?
1 REPLY 1
They delayed the release of v27 four months specifically to be Sonoma ready. The exact opposite has happened as it is the buggiest release cycle I have ever witnessed from GS.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
