riyadist
Solid Element Operations ( subtract)
Is there a way to clear subtract(gaps) from windows? A lot of windows so it is hard to arrange the object to the windows.
5 Replies 5
Hello riadiste,
Document/model view definition/...
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
How did you create those small horizontal gaps that cut through both the Wall and all Windows in it?
Hello Laszlo,
I also wonder and bet metal beams hidden on hidden layer. Isn't it ?
Christophe - FRANCE
Hmooslechner
You just need to have extra walls for each window extra and the walls without the windows also extra - just cut only the walls without the windows. But - the gaps cutout should be filled with something - i think - an extra set of SOE-geometries?
I hope @riyadist will tell us.
