Solid element operation - floor plan display?
I've made this type of irregular niche in the wall using solid element operations with the morph element. But it is not showing in the floor plan view. Is it possible to display it? Or what is the best workaround?
(I know that there is a similar topic/question from 2013, but I'm guessing something has surely changed in the past 7 years)
Nope.
Nothing has changed with regards to the floor plan view of SEOs.
Hello Mjera,
The best is sometimes the enemy of the good.
I draw a simple 2D line about this kind of detail.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Nope.
