‎2004-01-09
12:02 PM
‎2023-05-23
05:30 PM
Rubia Torres
‎2004-01-09 02:11 PM
Michael wrote:Screenshot? Preferably a 3D view showing the wall and the object?
Having completed a successful library object, we have tried to use it as the operator to subtract an opening in a vertical wall plane.
However upon execution of the operation the desire result of a hole in the wall does not materialize.
‎2004-01-09 02:38 PM
Michael wrote:Does your object have a relevant zzyzx parameter ? I had some problem with old library parts not using this "standard" parameter and SEO wouldn't work... I had to make use of it for SEO to work
What are we missing?
‎2004-01-09 11:14 PM
‎2004-01-09 11:59 PM
‎2004-01-10 06:02 AM
Michael wrote:You can also make the operator layer wireframe, if it helps.
Duh Michael turn the operator layer off.
Issue resolved
