Michael
Solid operation object into wall
Having completed a successful library object, we have tried to use it as the operator to subtract an opening in a vertical wall plane.
The objects depth extends on both sides of the wall surfaces.
However upon execution of the operation the desire result of a hole in the wall does not materialize.
What are we missing?
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
5 Replies 5
Djordje
Screenshot? Preferably a 3D view showing the wall and the object?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Does your object have a relevant zzyzx parameter ? I had some problem with old library parts not using this "standard" parameter and SEO wouldn't work... I had to make use of it for SEO to work
Michael
Here's a 3d and a plan view
Michael |:-)
Mac OSX 10.10
Michael
Duh Michael turn the operator layer off.
Issue resolved
Michael |:-)
Mac OSX 10.10
Djordje
Issue resolved
You can also make the operator layer wireframe, if it helps.
Djordje
HP Omen
