Solids Element Operation for a playground - slide ?
Hello everyone,
I am trying to create a slide for a playground, i use the mesh to create the bottom and then the wall tool to make the walls.
I want to cut the walls parallel to the slide so as there is always 50cm wall on the left and the right side while sliding.
I think I am stuck and the solution is right in front of me.
Any help appreciated
6 REPLIES 6
Erich
Why not use a complex profile for the slide section (that way you can profile the sides - give it variable thickness, etc.). Build it in plan then convert to a morph and tilt it into position.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
Wendy:
Create a copy of the Mesh.
Elevate the copy 50 cm.
Use the Pet Palette to Offset All Edges so the Mesh extends beyond the outside faces of the walls.
SEO the Walls from the Mesh, with Subtraction with upward extrusion.
Put the SEO Mesh on a hidden layer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
alemanda
Why not to test this wonderful object made one of the members of this forum?
http://archicad-talk.graphisoft.com/viewtopic.php?t=47352
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
I did that, used the beam to use the angle option, but since the slide is from several segments it tilts each one of them separately. How can I create it straight and tilt it to the right angle?
Done!!!!
Thank you so much!!
WHEeeeeeeeeeeeeeeeeee
