Splayed window reveals for broken arch window
Is it possible to have splayed reveals on both sides of a broken arch opening? Any advice gratefully received.
I am getting to that point in a project as well. So I have been thinking.
For my rectangle windows, I use the splayed opening in the windows library, and place it in the same spot as the window itself.
Is that how you do it?
I think for the arched top windows you're going to - well I am until I hear differently, create a slab, and SEO it with roofs etc until you get the splay to look as you like, and then save the slab with a wall hole ID as a window. . .
But, I haven't tried this yet.
I have done the same thing for rectangular windows, works a treat for external or internal splay. havent tried with both sides yet. I was hoping there might be an easier way than the slab SEO route but will give it a go and let you know how I get on. Cheers
