Splitting a linear element into multiple equal elemnts
Mike96
Is it possible to quickly and automatically split a linear element (line, polyline, arc, curve, wall, beam) into a number of equally long elements? For example, split a wall into 7 small wallies
Of course, it's easy to do it manually with straight elements by just using snapping, drawing one and arraying it, but with curved ones - it is not so easy already.
ArchiCAD 25
Windows 10
furtonb
I dont know about an automatic way in vanilla AC.
I usually deal with problems like this:
Set snap point values : divisions to the desired number (e.g. 7), place hotspots to the snap points, then cut the original element by the hotspots.
https://helpcenter.graphisoft.com/user-guide/76358/
You can also use the "distribute along" command to get the cut points.
To do it more automatically or to deal with larger sets, you could use Grasshopper - maybe the Python API is capable of writing such a command (select object, ask for the number of divisions, ask whether to keep the original element, return the segments), but I haven't tried it so far.
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
JSN
Python won't help you much here at the moment as the documentation does not list such geometry manipulation options: http://archicadapi.graphisoft.com/archicadPythonPackage/archicad.html
I would suggest the Grasshopper way as well - would be very easy to accomplish. The only donwside you have there is that you cannot alter your elements but you can re-create them as you wish. So take that in mind.
If you want a circular array then you can do that - it is an option in the array settings.
You can also distribute along a path (spline) if you do not want a circular distribution.
There is no way I know of to split an existing element into equal parts other than using the division snap points as mentioned and manually splitting the element.
