Stacking Two Corner Windows
I really have two questions:
First, I am trying to stack two corner windows, one on top of the other, but the second time I place a window it only creates half of the window and it's not on the corner of the building. What's the technique.
Second, is there a way to get a mullion or other corner piece than the frame?
Djordje
Doe the one on top have the Corner window function on?
Long time since I last used it, but would say yes, depending on the window type and parameters. Then again, the US version windows are different from the INT one ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I figured it out. The problem was a lack of patience! Thanks.
