Stairs in ArchiCAD 21
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-10-02
12:22 PM
2023-05-25
04:44 PM
Rubia Torres
2017-10-02
12:22 PM
don't know why can't see the pic, so here is the link:
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-02 01:16 PM
2017-10-02
01:16 PM
I would suppose it is 'easy' in ArchiCAD21 with new fancy stair tool.
ArchiCAD20 and before that, require you to use either the parametric object like stairs or the stairmaker.
If the parametric stairs won't do it, I would probably make the steps/treads part of the stair with stair maker and model the stringers seperately with a complex profile wall.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-02 01:29 PM
2017-10-02
01:29 PM
Erwin wrote:Yes. I’m making it in 21. Everything is all most great. Just can’t find the option there to decide that flight structure (this on the left and right side of the stairs) should to be straight on the bottom and “stepping” on the upper part. I can just make straight or just stepped. Hmmm. Is it possible?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-02 01:49 PM
2017-10-02
01:49 PM
I haven't tried 21 yet, so someone else will have to chime in to answer that. Have you looked at the ArchiCAD Youtube channel? There have been quite a few videos posted there already about the new stair and railing tools, with new ones popping up every so often.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-02 09:24 PM
2017-10-02
09:24 PM
I think the settings you are looking for the structure is the Beam not stringer, then make 2 beams and adjust settings as needed.
Is quite simple, but one make think that you would get this with stringers
. but not, you have to use Beam structure.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-02 09:32 PM
2017-10-02
09:32 PM
arqrivas wrote:Ahh. Super. Thanks. Will try it tomorrow. I knew I looked in wrong place
Is quite simple, but one make think that you would get this with stringers. but not, you have to use Beam structure.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-10-05 02:08 PM
2017-10-05
02:08 PM
Set the Beam option for Flights, and for the Beam, use the "Open Stringer" GDL Object. That will give you the shape you wish to achieve.
Use 2 "Open Stringer" Beams and set their position to the sides of the Stair as arqrivas suggested.
