2017-10-02
12:22 PM
2023-05-25
04:44 PM
Rubia Torres
2017-10-02 01:16 PM
2017-10-02 01:29 PM
Erwin wrote:Yes. I’m making it in 21. Everything is all most great. Just can’t find the option there to decide that flight structure (this on the left and right side of the stairs) should to be straight on the bottom and “stepping” on the upper part. I can just make straight or just stepped. Hmmm. Is it possible?
I would suppose it is 'easy' in ArchiCAD21 with new fancy stair tool.
ArchiCAD20 and before that, require you to use either the parametric object like stairs or the stairmaker.
If the parametric stairs won't do it, I would probably make the steps/treads part of the stair with stair maker and model the stringers seperately with a complex profile wall.
2017-10-02 01:49 PM
2017-10-02 09:24 PM
2017-10-02 09:32 PM
arqrivas wrote:Ahh. Super. Thanks. Will try it tomorrow. I knew I looked in wrong place
I think the settings you are looking for the structure is the Beam not stringer, then make 2 beams and adjust settings as needed.
Is quite simple, but one make think that you would get this with stringers. but not, you have to use Beam structure.
2017-10-05 02:08 PM
