2005-11-10
04:01 PM
2023-05-26
12:36 PM
Rubia Torres
2005-11-11 01:35 AM
LukasB wrote:because graphisoft cheated and simply put a ROTy 90 at the beginning of their column objects?
When I pick a steel beam from AC 9 library and I set it to be for example 2 metres long and I place it on my plan, and select it, I then see on my info box, wrong info about the top and bottom elevation heights. AC thinks that the length that I had set for the beam (2meters) is also the height of the beam (mistake only shown on the info box and not on the 3dmodel). This doesn't help at all when you have to deal with dozens of beams! Does anyone know what I can do about it? Is there a solution?
2005-11-11 08:47 AM
