2007-07-18 07:08 PM - last edited on 2023-05-26 12:34 PM by Rubia Torres
2007-07-18 07:37 PM
2007-07-18 10:19 PM
2007-07-18 10:34 PM
Joseph wrote:I asked the same question about a year ago: here
Always wandered, what is the use of Beam & Column Tool when we have Beam & Column Objects? I only use Objects in the default AC library, any one else?
2007-07-18 11:08 PM
2007-07-18 11:15 PM
TomWaltz wrote:I assume you mean Column & Beam Tool; but trim what? When I hear trim is see SEO?
I use them for an occasional trim piece here and there... that's about it
2007-07-19 12:17 AM
Joseph wrote:Trim in that context is a noun, like for moldings, bases, crowns, etc.TomWaltz wrote:I assume you mean Column & Beam Tool; but trim what? When I hear trim is see SEO?
2007-07-19 12:23 AM
2007-07-19 12:48 AM
Matthew wrote:matthew - i wouldn't even begin to use 'complex profiles' for steelwork. the steelwork objects are far more intelligent. they may take a little getting used to - especially for cutting angles - but they are far superior to the rather unfortunately named dumb 'complex' profiles . . .
Does anyone have a collection of steel sections for beams and columns that they would be willing to share?
2007-07-19 04:43 AM
~/archiben wrote:Or you could save even more time/money for a small investment in OBJECTiVEMatthew wrote:/.....your time would be better spent working out how to put stretchable cutting plane hotspots on the current steelwork objects - then all steelwork modelling can be done very quickly in the 3D window.
