2003-11-14 07:56 PM - last edited on 2023-05-26 03:30 PM by Rubia Torres
2003-11-15 03:26 AM
2003-11-15 06:21 PM
Karl wrote:Anybody tried Backspace?
Unless you guys have a trick...under Windows, the ctrl-. shortcut doesn't work for me anymore - I have to actually click on the stop button during a render. And sometimes (not always), the progress bar and stop button don't appear, so there's no way to stop the process.
If I go under keyboard shortcuts, it reports that ctrl-. is assigned to the system, so it isn't as if I accidentally reassigned it to something else.
So, hey, maybe something is working better on the Mac side these days!
2003-11-15 08:25 PM
Djordje wrote:Yup. Nothing stops it for me except clicking the 'stop' button - which doesn't always appear soon enough (for example, with the Sketch engine).
2003-11-15 09:11 PM
Karl wrote:By default, since ArchiCAD 8, the progress dialog is turned off
2003-11-15 09:49 PM
Ben wrote:Ahhh - I think this is what I was looking for. Upon further investigation, I'm finding that command + (.) does seem to work for me in the section/elevation window as well as the 3D window. It results in an "Errors occured during the last opperation" message. Where I was having issues was the rendering window (while using the sketch engine). W/out the progress dialog box there is no way to stop it - at least as far as I can tell - and while it doesn't appear instantly, it does show up eventually and is better than force quitting or waiting 20 min. for the rendering (which you're just going to trash anyway) to finish.
Strange really. But to activate it you can find it under your preferences, see image. But CTRL+. hasn't worked for me since ArchiCAD 8.
2003-11-15 10:28 PM
2003-11-16 12:33 AM
Karl wrote:well you all had me going there. i went back and tried it again - 'Cmd' + '.' does still work for me. i have to double-press the '.' - but then i've always done that anyway.
2003-11-16 03:22 AM
~/archiben wrote:Well, the progress dialog has always been enabled for me - just choose not to appear until far into a rendering sometimes.
karl - try double-tapping the '.' key whilst you're holding 'Ctrl'. if that works for you i guess the macs are still hanging out the back . . .
2003-11-17 04:56 PM
2003-11-18 01:26 AM
